MO
AZ
07-08-09, 08:15 AM
Well, If you really want to use the manufacturer reccommended stuff...You might be able to look at the manual at Home Improvement Projects, Product Manuals & Home Management Tools - Managemyhome.com. Its Sears new site for parts and manuals.
You would need the Sears model number for the mower. Might be under the seat or on the frame somewhere.
If you don't want to go to that trouble a straight 30 wt is a pretty common grade as BFH noted. Might be a little thick if you plan on any cold weather use.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
TN
07-08-09, 08:21 AM
Straight from Kohlers website:
10W-30 (Command Oil) is recommended for Command, Courage, Command PRO, Command PRO CS, Triad OHC, and Aegis engines for temperatures above freezing (32°F, 0°C). SAE-30 is an acceptable substitute if temperatures are above 50°F, 10°C. K-Series and Magnum engines should use SAE 30 (Magnum Oil) above freezing. 5W-20 or 5W-30 can be used in all engines when temperatures are below freezing. For more complete oil specifications refer to your owner's manual. For optimum performance, Kohler's special blend oils are available from your KOHLER dealer.
Synthetic oils meeting the classifications listed in the owner's manual may be used, however oil changes still need to be performed at the recommended intervals. To allow the piston rings to seat properly, Kohler recommends operating a new or rebuilt engine for at least 50 hours on standard oil before switching to the synthetic oil.
Failure to use recommended multi-viscosity oil in a Kohler with hydraulic lifters may cause lifter failure.
Kohler Engines: Home
PA
07-08-09, 08:33 AM
You can pay $6 a quart for some special synthetic oils, or $1.49 a quart for oil that still meets your engines specs, but the MOST important thing is change it when you are supposed to. The best oil in the world won't help much if you don't change it with fresh as needed.
MO
07-08-09, 09:01 AM
I do not know how long it has been since the oil was changed. I just bought the mower about 2 weeks ago and had to do a few repairs to it to get it up to par. I have yet to use it but the last thing that needs to be done is to go ahead and change the oil and spark plug. It just looks like I just need to get some 10w30 Command oil.
