Ryobi 2800R Fuel Line Replacement
foreverlookin's Avatar
07-08-09, 07:46 AM   #1
The fuel lines on my Ryobi 2800R need to be replaced so I got a generic replacement kit from Canadian Tire that included a primer bulb. When I went to install I noticed that this unit has a return line back to the gas tank which appears to be just a hole in the tank and none of the line, it appears to be 1/8, that came in the kit appears like it will work. Any suggestions?
Thanks Steve
hopkinsr2's Avatar
Non-US
07-08-09, 07:57 PM   #2
Some units use 2 different size lines... If the kit you got is a generic one,, it may not have both sizes...Take the return line from the trimmer to you're nearest small engine shop & they will fix you up!!! Good Luck... Roger
