Tecumseh 10hp engine only runs when choke is on, what's wrong?
Old 07-20-09, 10:57 PM
I have a 10hp horizontal shaft Tecumseh engine that will only run with the choke closed. If I open it, it will die.
Any ideas?
Thanks in advance.
Old 07-21-09, 01:10 AM
cheese's Avatar
Received 20 Votes on 17 Posts
The carb needs cleaning. Take the bowl off and clean it and the bolt that holds it on. There should be a very tiny hole near the end that is probably clogged, causing the problem.
