carb prob.
Old 07-24-09, 08:42 AM
B
carb prob.
hi i have a b/s model446777, type0244e1,code031222yg with a nikki carb on it only # i can find are 791093 266 &7x02n-741
the motor wouldnt run only when choke was all way out so i just took it off to see if i had a stuck needle and seat or what ever, there was a bunch of junk in the 2 holes under the bowl which i took a piece of wire and cleaned. when i took the yop off where the fuel line hooks there seemed to be no gasket just remnants of what might have been one, is there supposed to be a gasket there. what else should i do while i have it apart? thanks in advance Buck
Old 07-24-09, 09:32 AM
A
Maybe this will help.
Parts list:
http://www.briggsandstratton.com/mai...=MS5195_LO.pdf
Old 07-24-09, 09:36 AM
BFHFixit's Avatar
Originally Posted by Airman View Post
Page 5 .
Old 07-25-09, 04:06 PM
B
i've taken the carb off and cleaned about everything i can see. the one prob. i might be having is the inside bottom of the bowl where the selonoid is , is really dirty but i cant get the selonoid out to get it cleaned good ,the housing just spins around and wont break loose from the bowl what trick am i missing ?
Old 07-25-09, 09:22 PM
cheese's Avatar
Received 30 Votes on 25 Posts
You have to remove the nut on the inside of the bowl.
Old 07-26-09, 04:44 AM
B
dont see any nut in there but after further inspection i can see i have to grind down the flat sides of a wrench and maybe it will fit between the housing of the switch and the bowl. is there anything i can do to test the selonoid to see if its okay ohm meter etc?theres gotta be wires in the thing and if its just spinning around that cant be good either but they are exspensive so i'd like to ck. it
Old 07-26-09, 10:42 AM
cheese's Avatar
Ok, some had a solenoid with a nut in the bowl but not all (wish they'd pick one design and stick with it). Put 12 volts to one terminal and ground the other terminal while listening for a click. If it doesn't click, it needs cleaning or replacing. Turning the housing around may have broken the wires. It takes a thin 1/2" wrench to unscrew it if no nut inside the bowl.
Old 07-26-09, 12:07 PM
B
yea i had to shave a wrench down to fit between the bowl and switch, but its working good i checked it. where are the freakin jets i see em in the parts book but are they the ones that are in the plastic tube?
Old 07-26-09, 07:25 PM
cheese's Avatar
Yep, the jets are in the plastic tubes that drop down into the bowl. Be careful if you blow air or carb cleaner through these, as they can pop out and blow away (learned the hard way).
Old 07-27-09, 11:35 AM
B
Dammit !
yep ! I just did too !! now i gotta order the jetsone is a standard the other is a high altitude i think i'll just get the standards seeings i aint at no high alt. here in fla.Beer 4U2
