Craftsman riding mower 21.5 hp OHV B & S leaking fuel
Old 07-26-09, 11:49 AM
K
We were given a Craftsman LXT 1000 riding mower with 21.5 HP OHV Briggs and Stratton Intek Twin by an older gentleman who didn't want to deal with some problem with it. After charging the battery the thing fired right up and sounds great. The problem is that it is squirting fuel out of a round black plastic diaphragm type part, after the little fuel pump (sorry after the clear fuel FILTER), so between the fuel filter and the engine and mounted to the outside front of the engine, on the same side as the fuel filter. I can't seem to find a manual or an exploded view online-what is this part and how to find a replacement? It is Japanese made. I assume this part has failed internally. The mower looks almost new, seems a little strange.
Old 07-26-09, 02:33 PM
hopkinsr2's Avatar
If it's an engine part, you can look it up on briggsandstratton.com, or if it's something sears put on, use searspartsdirect.com... You need the engine numbers for briggs & the mower model numbers for sears... To me it sounds like a fuel pump need an overhaul, but see if you can verify the name of the part..... Roger
Old 07-26-09, 03:09 PM
A
Old 07-26-09, 07:28 PM
cheese's Avatar
Received 30 Votes on 25 Posts
If it's coming from a round black plastic piece with 3 fuel lines connected to it, that's the fuel pump and it needs to be replaced. I would also replace the line from the pump to the carb as well, since it is often cracked and leaking on many mowers I see.
