wiring diagrams
Old 07-27-09, 10:30 AM
wiring diagrams
Where can I find the wiring diagram for a 15 horse B&S model 28N707, and a 18 horse B&S model 422707.
Thank you
Jack
Old 07-27-09, 08:14 PM
cheese's Avatar
I don't believe there is such a thing.... these engines don't have wiring harnesses in them or anything, just a couple electric components with plugs. The diagram usually goes with the equipment the engine is mounted on. What are you trying to figure out?
Old 07-29-09, 01:50 PM
I want to know where the wire from under the head goes to keep the battery charged?
Old 07-29-09, 02:40 PM
31YTech's Avatar
A common place to hook this wire is the large post on the starter solenoid with the positive cable going to the battery.
BUT,
Do NOT cut the little pin connector off the end of this wire to hook it up, There is a diode next to this connector that keeps battery voltage from feeding back to the stator and burning it up.
Get the proper connector to plug into this wire then extend to the needed length to reach the starter solenoid post.
Good Luck
Old 07-29-09, 06:23 PM
thanks
Thank you very much for your help.Maybe Auto Zone will have the wire I will need.
Old 07-29-09, 07:54 PM
31YTech's Avatar
Any Briggs dealer will have or can get a wire pigtail to plug into the pin connector on the stator.....
Old 08-03-09, 08:08 AM
same engine
What would make this 15 hp engine hard to turn over?Good battery and starter.Could it be the coil is to close to the magnet?
Old 08-03-09, 09:20 AM
31YTech's Avatar
Valves worn out of adjustment, This causes the mechanical compression release to not work properly.
Adjustment procedure;
Good Luck
