New Ryobi Weed Eater Problem
Old 08-01-09, 12:51 PM
Unit began to die as though out of gas. Found cracked fule line and primer bulb - replaced both. Now will start only after priming cylinder with gas. Runs for a second then dies. Not getting gas. Thoughts?
Old 08-01-09, 01:56 PM
I moved your post to a thread of its own. Multiple postings in a thread get confusing.
The title you used says "New". Is this a recently purchased unit or are you referring to a new problem?
Give of a model number, age of unit and history leading up to current problem. What brand and model number carburetor is installed on this unit.
Old 08-01-09, 04:33 PM
hopkinsr2's Avatar
Airman has you on the right track... If this is a new unit,, Take it back for warranty... If it's a new problem & it's an older unit & the fuel lines & primer bulb are rotton,, so is the inside of the carb,, You'll need a carb rebuild kit & adjust the meetering lever & also make sure all the bolts around the cylinder & the rest of the engine are tight & the gaskets aren't leaking..... Roger
Trackbacks are On
Pingbacks are On
Refbacks are On
