John Deere weak spark
Old 08-02-09, 08:47 AM
I ahve a 14 horse kawasaki motor on a comercial walk behind mower. I had no spark, unplugged the kill wire, sanded the magnet and looks pretty clean still no spark. So I bought a new coil from john deere and still no spark, when I grabbed the wire it zapped me but it does not jump the gap in a new plug. I dont know where to go from here, could the magnet be bad? Also when I put the new coil on I used a cardboard business card to set the gap thought that would be fine.
Old 08-02-09, 10:11 AM
Received 4 Votes on 4 Posts
Sanding the magnet = no difference, the business card to set the armature gap is fine = .010.
Are you sure you don't have an igniter on that thing? If not you probably have the spark, but aren't seeing it or don't have the plug well grounded to check it.
Try putting a little gas (tablespoon) in the cylinder and try to start it with no choke and full throttle.
Old 08-02-09, 11:34 AM
Well I dont know if I have an igniter or not all I have is a coil with a spark plug wire and one single wire I assume is the saftey switch to keep it from running if the trans is not in neutral. If there was and igniter were would it be or look like.Thank You for your help
Old 08-02-09, 11:45 AM
We'll have to have some mower model and engine numbers to figure just what you have.
A lot of those have igniters on them and if it's bad the new coil won't do you any good.
Old 08-02-09, 12:09 PM
cheese's Avatar
Received 21 Votes on 18 Posts
Follow the small wire that plugs onto the coil. If it goes to a small metal square thing on the side of the engine, that is the igniter. I suspect you do have one and it is bad.
Old 08-04-09, 05:40 PM
bought new ignitor and now have great spark thank you for your help
Old 08-05-09, 12:57 AM
cheese's Avatar
Glad we could help! Thanks for the update!
