08-03-09, 04:53 PM
6.75 hp briggs
model 125k02....starts, runs fine.. turn it off and then try to start it. It tries to start, tries to idle up, but acts as if it is deiseling, tries to idle up and backfires thru the exhaust for approx 20 seconds or so, then dies..... cools off and runs great...already built carb...is the coil breaking down, or, stuck valve...help..help, help me if ya can.......:
GA
08-06-09, 08:08 PM
Usually a coil shuts the engine off when it gets hot and will not allow re-start until it cools.
The breather hose is not related to the problem.
A valve problem is possible, but not so likely. Does it lose compression when this happens?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
NH
08-07-09, 08:47 AM
Does sound like a coil going bad. It could also be a clogged vent in the gas cap.
