walbro wy carb
Old 08-03-09, 06:53 PM
walbro wy carb
I have a green machine trimmer with a walbro wy50 carb and put new gaskets and cleaned carb. the engine will run if i put a little gas in the carb but will not start from pumping the primer. I took the carb back apart and can sqirt gas both ways through the little check valve under the metering lever. I think it is messed up. I thought it was only supposed to flow out to the nozzle. Is there any where to buy just the check valve for this? Thanks for your help.
Old 08-03-09, 07:58 PM
Tolyn Ironhand's Avatar
Did you replace the diaphragm? most times I have fuel issues replacing that does the trick. Otherwise you may have to remove the needles and clean them out.
Old 08-03-09, 08:02 PM
hopkinsr2's Avatar
The warlbro website has an excellent troubble shooting, repair manual on line... I use it a lot check it out & it'll answer all you're questions.... Roger
