husqvarna transaxel gear oil
vt_hokie1's Avatar
08-04-09, 12:33 PM   #1
I have a husqvarna YTH150 riding lawn mower. I just ordered some new bearings and bushings for the transaxel I need to know how much gear oil to put back in. Also need to know if I need to apply some kind of gasket material around case as there is no gasket but it was sealed somehow when i took it apart, it did not appear to have anything on it , but something was holding it together after the screws were removed.
indypower1's Avatar
NH
08-04-09, 04:05 PM   #2
I don't know how much oil it takes, but since it is a Hydro, it uses 20W50 Synthetic oil. As for the gasket, that would be "Anerobic Gasket Maker" which is available at you local auto parts store.
vt_hokie1's Avatar
08-05-09, 07:22 PM   #3
Thanks for the info. After doing a little more research i found that it was 20W50 as opposed to gear oil also found out about using the gasket material. If what i found was correct i believe it will take approx. 70 to80oz of oil. if anyone knows the amount for sure it would be appreciated.
