IL
Non-US
08-05-09, 12:11 AM
How often do you use it?? If only once in a while,, leave it till you need fuel lines or a carb kit... If you use it for commercial,, maybe once a month... The average homeowner cutting firewood could easily get 3 or 4 seasons cutting if you don't spill sawdust into the tank when you take the fuel cap off.... Hope this helps.... Roger
IL
08-05-09, 08:04 PM
Thanks Roger. Appreciate the reply. The saw is for home use but I recently used it daily for long periods in cutting up a couple of large, felled trees in my yard. As I tended to the air filter and exhaust screen, plug, etc., I noticed that my manual didn't indicate anything on fuel filter duration. Then I got to wondering how long they last in actual saw use hours. I started having an issue with the saw bogging down under load, (otherwise runs great), so I thought I'd start with a fuel filter replacement before going further, (though it's probably okay since the saw isn't dying or running eratic or anything??).
I'll submit a post on the forum for help with the saw delimma, but I realized I should know a bit more about fuel filter anyhow.
Visser
Visser
