Overheating (?) JD lawn tractor
NoTTD's Avatar
IL
08-08-09, 03:01 PM   #1
I think my JD 155 lawn tractor is overheating. After running about 1/2 hour is simply dies. It will then backfire on attempted starting. After cooling, no problem starting - but cycle repeats. Today's weather: 90+F, Midwest humidity.
I have already removed the engine (Kohler CV15S - 15 HP) cowel and cleaned out the mouse debris. (Ongoing problem.) No problems with the Big Three (fuel, air, spark). Any advice would be appreciated.
cheese's Avatar
GA
08-08-09, 05:33 PM   #2
Sounds like a failing ignition coil.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
NoTTD's Avatar
IL
08-16-09, 09:11 AM   #3
Thanks. Is this a difficult repair? Where is the coil located on this? 'm a fair Ishade tree mechanic and usually keep the mowers running, but have not done this.
marbobj's Avatar
IA
08-16-09, 11:34 AM   #4
It mounts close to the flywheel and gets its signal from the magnets on the flywheel. There's a couple of small bolts that mount it. The gap between the coil and flywheel is a standard .010. Most of us put a business card (or about) between the coil and flywheel magnet, let the magnet draw it down against the card, tighten the bolts, turn the flywheel a little and pull out the card.
Just pull off the flywheel shroud and you'll see everything.
