weedeater fuel line problem
fixin2's Avatar
08-15-09, 09:10 AM   #1
Does the tank seperate from the body? I am working on the same issue ( gas lines ) and I cannot figure out how to get into the fuel tank where a piece of fuel line is broken off in the hole. Also, I have the one coupling/connector to attach the filterline to the carb line, but what attaches the primer line to the tank? There is no fitting that I can see. Is it just shoved into the hole where my previously mentioned line is broken?
Airman's Avatar
TN
08-15-09, 10:45 AM   #2
Posted By: fixin2 Does the tank seperate from the body? I am working on the same issue ( gas lines ) and I cannot figure out how to get into the fuel tank where a piece of fuel line is broken off in the hole. Also, I have the one coupling/connector to attach the filterline to the carb line, but what attaches the primer line to the tank? There is no fitting that I can see. Is it just shoved into the hole where my previously mentioned line is broken?
I moved your post to a thread of its on to prevent confusion. The thread you posted to is three years old.
Start by posting the model number of the weedeater you have the problem with?
