Homelite Trimlite UT20760 25cc
john03's Avatar
08-15-09, 03:04 PM   #1
Unit won't start, I have checked compression, installed new plug, fresh gas.---Still not firing, I have I think a good blue spark when I ground the plug to the body. What next?
cheese's Avatar
GA
08-15-09, 07:25 PM   #2
Add a little gas into the spark plug hole, put the plug in, and try to start it. See if it runs for a second or two.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
john03's Avatar
08-16-09, 08:19 AM   #3
Posted By: cheese Add a little gas into the spark plug hole, put the plug in, and try to start it. See if it runs for a second or two.
Thanks, I'll give it a try. One other thing, I have not started this unit in three years. But with the plug out there seems to be gas coming into the cylinder as I crank the unit.
cheese's Avatar
GA
08-16-09, 07:33 PM   #4
Ok, then it may be that it is flooding and the carb needs repair. If it has that much gas in it, that's probably the case.
God bless!
Airman's Avatar
TN
08-17-09, 03:06 AM   #5
I believe your trimmer has a ZAMA carburetor. If that is the case the links below will help with rebuilding the carburetor.
USA Zama : Service Tips
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf
john03's Avatar
08-23-09, 01:36 PM   #6
Thanks Airman, I used the Zama link to get the clean carb info. I used it and used a medicine dropper to put gas in the spark plug hole, replaced carb and fired it up. The cleaning apparently had done the trick. It's running good.
