B & S starts but won't run
Ryderman's Avatar
08-19-09, 05:05 AM   #1
B & S model 9502-97041-01 starts fine but won't run unless the primer is constantly pressed. It has a new gasket/diaphram but is starving for fuel. It is clean, just doesn't pump fuel. I'm lost.
Airman's Avatar
TN
08-19-09, 06:04 PM   #2
Could you verify the model number for correctness.
Ryderman's Avatar
08-21-09, 09:09 AM   #3
Model embossed on front is:
Model Type Code
95902 3185 01 97041551
Airman's Avatar
TN
08-21-09, 09:57 AM   #4
Use these links to clean your carburetor. Look closely at the main nozzle.
Removal of Pulsa Prime Carb from Briggs 10L900 Series Engine
Disassembly of Briggs and Stratton Tank-mounted Pulsa-Prime Carburetor
Ryderman's Avatar
08-22-09, 02:03 PM   #5
Removed carb. Removed main jet screen but was unable to press jet out from carb throat. Checked main jet by inserting small drill. Removed prime button. Sprayed every orifice with carb cleaner and blew it out with high pressure air. Reinstalled and it now operated normally. Tnx Airman
