help with Grundomat air compressor
Old 08-22-09, 08:44 AM
Hey,
I have a 70' Gundomat air compressor that starts up but when it loads up with air it shuts down. Anyone have any troubleshooting tips to help me fix this myself?
Old 08-22-09, 09:57 AM
That particular make doesn't sound familiar, but all air compressors I've seen have the pressure setting on them to kick the compressor off when the tank reaches the desired pressure.
I suspect either yours is set too low or is faulty.
Usually those are a spring plunger type affair with electrical contacts and wires coming from it. It normally isn't hard to find or figure out how to set it.
Old 08-22-09, 10:38 AM
GregH's Avatar
Super Moderator
You will need to find out what control is "shutting it down.
If the pressure control is not restarting when the pressure in the tank drops you could have a plugged air connection between the pressure switch and the tank or the switch needs replacing.
If the switch closes and energizes the motor but it does not start then you could have a bad motor.
If you haven't already and are comfortable working with electricity then remove the pressure switch cover and see if the contacts close when the pressure drops.
