tow cable ford lt 12 h
Old 08-23-09, 06:56 PM
how do I change the tow cable on a ford lt 12 h?
Old 08-26-09, 11:11 AM
bontai Joe's Avatar
tow cable?
I am not sure what a tow cable is? I'm imagining a steel cable attached to the rear of the tractor with a bolt thru the hole the hitch pin normally uses? If yes, then unbolt it with a wrench.
Old 08-26-09, 05:22 PM
Tow cable is a cable attached to transmission linkage to lock transmission in neutral so the tractor can be moved when the engine is not running.
