Troy Bilt Super Bronco 13AX60TG766
Received 0 Votes
Good morning all! The R/C airplane club that I belong to has a Troy Bilt Super Bronco riding mower model 13AX60TG766. After having the drive belt(s) replaced by a mobile mechanic, the gas pedal is now extremely difficult to push down to reach top speed. I have looked online for diagrams and advice alike but have yet to come up with a cause or solution. The mechanic gave up on correcting the issue, but offered that it may be due to a missing spring. The only diagram I found for the drive system shows two springs [Troy-Bilt 932-0384 (replaces 732-0384)
Spring, Extension,.62 Dia x 6.12 and Troy-Bilt 732-0963
Spring, Extension,.50 Dia x 6.37].
Has anyone else encountered a problem like this?
Thanks in advance,
Rick S
Clay County Flyers R/C Club
Thanks in advance,
Rick S
Rick,
It sounds like the variable speed pulley is hanging up, That's the double one in the back that the front and rear belts go around.
With the top (rear) belt removed you should be able to grab the center section of the pulley and pick up on it very easily and have it drop back down easily on it's own.
Good Luck
Good Luck
Remove the battery and battery tray, There will be a spring loaded idler pulley on your upper right. Just pull the idler back and pop the belt off of it. Then you can pull the belt away from the variator pulley to check it.
The trans pulley must be removed to remove the belt completely off the machine. But you don't have to do that just to check the variator pulley.
Good Luck
Good Luck
Received 0 Votes
Troyy-Bilt Super Bronco
Does anyone know if there was feedback as to the actual fix for this gentleman's problem. Changed the drive belt on my Super Bronco and have the same symptoms. The pedal is hard to push and i cannot reach what should be top speed.
Hello kagnew,
Mr Cheese is correct on belt changing.....
But, Give this a try. Put your speed selector in the fastest speed setting, With the trans shifter in neutral push the clutch and start the engine. Now let the clutch pedal up slowly and see if it comes all the way up, Push it once more and let it up. Now push it again then put the trans in forward gear and see if you get full speed.
What this will do is properly position the belts in the variator, When you finish mowing shut the engine off while your holding the clutch down. This will reduce pressure needed to push the clutch upon re-start, Lastly.... The speed selector lever shouldn't be moved without the engine running and clutch pushed down or the belt positioning procedure may need to be implemented afterward.
Good Luck
Good Luck
