Yard-Man Straight shaft Trimmer
Old 08-25-09, 07:09 AM
Angry Yard-Man Straight shaft Trimmer
Have a 2 cycle Yardman straight shaft trimmer that I just bought a year ago - worked beautiful until one of the kids decided to go trim with it. It was purchased for use with a blade rather than string. He used it and got weeds tangled around it and just kept running it until it bogged down and died. Well - we haven't been able to get it to start since! GRRR - Put a new plug in it and cleaned the breather - still no luck. It turns over really well just won't fire up now. Any help would be great - I really don't want to have to tear this thing apart if I don't have too. It worked like a charm and fired exactly as it was supposed to until he got it all tangled with weeds!
Old 08-25-09, 08:13 AM
hopkinsr2's Avatar
Is the plug wet?? Have you checked for spark @ the plug?? Ground it to steel of the engine, hook the plug up to the wire & pull it over.. Also check for compression..You said it turns over really well.. Can you verify he used a gas & oil mix in the tank,, not straight fuel?? You may even pull the muffler to make sure it's not blocked & while it's off look into the cylinder thru the port to check for any scoring on the piston or cylinder...Good Luck,, Roger
Trackbacks are On
Pingbacks are On
Refbacks are On
