B & S 6.5 HP EZ Start push mower running problem
cmheinrich's Avatar
08-27-09, 09:53 AM   #1
I have a couple years old Troy Built push mower, It has a 6.5 hp b and s motor. Model number 123K02-0336-E1 05031851. It will run if you prime it but is really jerky. And it will stall out as soon as it runs out of primed up fuel. any help would be great!
geogrubb's Avatar
MO
08-27-09, 12:25 PM   #2
It sound like the bowl nut(main jet) is clogged, remove the bowl nut and clean 2 holes at the botton and one through the center, might as well clean any gunk from the bowl also, if you remove the airfilter housing be very careful not to damage the gasket between the housing and the carb, if it is damaged it must be replaced or the primer will not work. Have a good one. Geo
cmheinrich's Avatar
08-27-09, 01:52 PM   #3
Tried that. No luck. Should I get a carb rebuild kit?
