Need a replacement engine
Jack B.'s Avatar
AL
08-27-09, 04:25 PM   #1
Does anyone know where I might find a replacement engine for a B&S M-31C707, T-0175-E1 I/C, OHV, AVS? When I tore the engine apart, it had slung a rod and tore everything up bad. It goes on a 2003 Murray rider.
31YTech's Avatar
FL
08-27-09, 07:38 PM   #2
Jack,
You could probably get by with a shortblock engine which is Briggs part#697761 and list @ $445.00.
But, I found THIS one, It is not a EXACT replacement for your old engine but uses the same shortblock as yours. The differences may be the throttle controls/charging system or if your engine has a fuel pump this one doesn't, But any of these parts can be swapped from your engine to this one with no problem.
Good Luck
Jack B.'s Avatar
AL
08-28-09, 10:51 AM   #3
Dose anyone have a copy of what B&S model, type and code stand for?
indypower1's Avatar
NH
08-28-09, 11:28 AM   #4
Posted By: Jack B. Dose anyone have a copy of what B&S model, type and code stand for?
You can find that info at Briggsandstratton.com
Square Head's Avatar
CANADA
08-28-09, 07:34 PM   #5
If you did some searching, you could find the answers all by your lonesome.
Nice find BTW 31YTech - Cheers.
