Champion Spark Plugs.
I have a couple of older units in the garage.
My snow blower calls for a RJ8C plug. All I could find was a J8C Plug. All they the same plug? Did Champion just drop the "R" id?
The manuals I'm using are from the early 80's.
Square Head,, can you recheck the plug number?? The "J8C" sounds like a pretty cold plug for a snowblower.... Any I see have an "RJ19" or an "RJ19LM" in them (most L-head brigs & tech) which is a hotter operating plug than the "J8C" for the cold temps a snowblower runs in... What engine are you running??? Roger
Received 0 Votes
The correct plug for your engine is a RJ17LM
Engine manual:
http://www.cpdonline.com/692509.pdf
See page 5 for plugs:
http://www.tecumsehpower.com/CustomerService/BSI.pdf
Engine manual:
Airman has the right info in the link he posted(( Thanks Airman)) In Northeastern Ontario,, we may have different spec engines I'm thinking,, 'cus I see lots of snowblowers & even push type lawnmowers from the factory with the "RJ19LM" plug in them.... I just kinda thought that was the one to use.... Nice & hot to burn the carbon off,,,,Right?? Square Head, Use the RJ17LM as Airman has suggested & you can't go wrong.... Roger
Engine manual:
Engine manual:
Thanks guys.
Received 0 Votes
I ran into this before.I have na old champion spark plug cross reference book(haven't seen it since I moved) and some models do call for that plug.The heat range is important.It is ok to go 1 heat range hotter or colder than the plug called for but a plugtoo hot can cause the engine to fire at the wrong time because it stays red hot and this (red hot electrode) can ignite the fuel too soon.Additionally the plug could melt and break off.If too cold it will probably just foul the plug.IE,in racing bikes where engines are run at constant high speed,a colder plug might be ideal .One other thing,be careful that the plug is the same reach;too long will hit the piston or valve.G'luck
