craftsman 580.752330 wont pump detergent
Old 09-04-09, 11:38 AM
G
bout 3 years old..i dont recall ever using the siphon but went to start up everything went fine..water came out good..used the soap tip..but soap wouldnt pump out...i unscrewed the area where you place the siphon and made sure it was clean..put the ball and spring back but still nothing...i also turned that large spring thing (idk the name) near that pump to see if anything happened but nothing
any help?
Old 09-04-09, 09:10 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
If you used the soap tip, and it isn't partially clogged (causing too much pressure in the line), then I'd say there is still a problem in the siphon valve.
