Mantis Tiller won't till
Received 0 Votes
I have a Mantis Tiller that I bought new about 6 years ago. I sent it to the mechanic because the tines were turning as soon as I started it. The mechanic replaced the carburator, and the tiller worked fine while in the air. However, when I got it home, I put the tiller in the soil, and it tilled fine until I got a bunch of tall grass jammed in the tines. I turned the tiller off to remove the grass, but then when I restarted it, the tiller wouldn't accelerate, and when it did, and it was put in the soil, the tines would stop turning and the tiller would try to die. Can you tell me what is wrong and how I can fix it?
Take it back to your mechanic and have him adjust the carb to run under load..explain just as you did here the problem and it should be a simple follow up with apologies for your time.
Unless that grass got all wedged up between the tines and axle so badly that it's binding. Did you slide the tines back some to be sure nothing is wrapped around it near where the shaft comes out of the housing?
Received 0 Votes
I did pull the tines off and pulled all the long weeds/grasses out of it, but it didn't help. However, the noise it's making when I hit the accelerator sounds just like the noise it makes when I get something jammed in the tines and the tines can't turn. Is it possible that something got jammed deeper where I can't see it?
Received 0 Votes
Same problem, but with a Troy mini-tiller
My Troy-bilt mini-tiller is doing the same thing - engine is a 2-stroke Tecumseh, starts fine (LOUD!!), but won't cut the mustard, if you will.
Bad carb, or a gearbox issue?
Received 0 Votes
Tiller saga continues....
The little bugger cranks right over 1st pull ready to eat dirt, tines revolving nicely.
When I set it down on the ground, the tines stop. Poss. gears in the box worn out. Is it anything like a car differential in there?
Received 0 Votes
I just went outside and spun it up.
The tines seem to be meshing intermittently, leaves me feeling it's a worn gear in there. If the clutch was failing wouldn't the tines simply not spin?
At any rate, it's a winter workbench job; I'll pull it apart and see what's what. I'm sure that gears, etc. for this thing could be pricey enough to make a new electric one attractive.
Thank you, jerilowe, for the help.
A slipping clutch would turn the tines until you put a load on it, just like a slipping clutch in a car...it will still spin the wheels with the car jacked up but not when you try to drive it. Could be gears too... it's one of those things that can't be diagnosed well over the internet.
Received 0 Votes
1st off, Cheese; I meant to direct my thanks to you.
One final request, and that is: who/what's a good source for
parts for these critters.
And- many thanks again for the advice.
Jim in Dartmouth MA
Jim in Dartmouth MA
