wiring diagram needed
sleepy2008's Avatar
CANADA
09-11-09, 11:54 PM   #1
Does anyone have a wiring diagram for MTD lawn tractor model #134E452F515? I had to change the motor to a Tecumseh as the original blew up after I bought it.When I first put it on it worked fine then the tranny broke and tried to put on other tractor but wouldn't start so put back on this one and have had problems starting and then trying to shut off. There are 3 wires on motor-green red yellow if I hook them to the same wires on tractor it wont start unless I unhook wire that goes to lights then it won't shut off unless i touch that wire together. If I switch the other wires around it tries to start backwards. Any help will be appreciated:
PS motor is OHV 135
SPEC 206915E
DOM 03192C80047
ENGINE FAMILY 3TPXS:3582AA
ENDURO XL/C 12.5HP
Square Head's Avatar
CANADA
09-13-09, 08:44 PM   #2
If you go to the Briggs web site you will find the diagram. Did the tractor come with a Briggs motor?
The Tecumseh site as well.
