Toro weed eater runs rough
dino64's Avatar
09-16-09, 03:41 PM   #1
My Toro weed eater model 51938 is running rough. This problem has just started. It runs rough with a few burst of full power. It will idle just fine.
Not sure what's going on, can anyone help please?
Thanks,
Dino64
CAMINO KID's Avatar
WI
09-16-09, 06:33 PM   #2
It sounds like your plug is loading up with oil and is not cleaning up until you rev it up to full power. Your plug might be too cold and might have to be replaced with the next hotter plug. And while you are at it remove the spark arrestor screen in the muffler. That could also be closing up on you for good breathing.
dino64's Avatar
09-17-09, 08:20 AM   #3
Camino Kid
Thanks for your reply. I checked the arrestor screen and it was clogged. How is the best way to clean it or do you replace it. The muffler appears dirty and moist inside. Should that be replaced.
Thanks,
dino64
Airman's Avatar
TN
09-17-09, 09:43 AM   #4
I remove muffler and burn carbon off using a MAP torch.
dino64's Avatar
09-17-09, 12:25 PM   #5
Thanks guy's for you help, I removed the arrestor screen and cleaned it the best I could and it is running like the day I bought it.
Thanks again,
dino64
CAMINO KID's Avatar
WI
09-18-09, 04:28 AM   #6
Unless you live on government land or park or if your subject to wild fires, you can leave the spark arrestor out.
