Cub Cadet cc4125 not starting
Old 09-19-09, 01:41 PM
My Cub Cadet cc4125 string trimmer will not start. When pulling the pull cord, it comes out with no real resistance. Normally the EZ Start System would apply resistance after about 1-2 inches and not require much of a pull to start. Now, no reisstance and won't start. I replaced spark plug and no change.
Fresh gas, no change.
Any thoughts?
Old 09-19-09, 08:48 PM
cheese's Avatar
Pull the spark plug out and see if it has compression when you crank the engine. Sounds like it doesn't. It could be a valve problem or a broken connecting rod. Was it run without oil?
Old 10-06-09, 02:19 PM
sorry for the delay in responding. Finally got a compression test done. zero pressure seen.
not sure if I should start with cylinder gasket or inspect the valves, or piston rings?
Thanks for the help.
Old 10-06-09, 03:19 PM
If this trimmer is a overhead valve,check the owners manual for valve specs. .They could be out of adjustment causing no compression,also check to see if the push rod came loose from the tappet.Hope this helps.
Jerry
