Ryobi Trimmer will NOT start
Old 09-19-09, 03:37 PM
Red face Ryobi Trimmer will NOT start
I have a Ryobi 725r trimmer that will not start. I replaced the tank along with all fuel lines etc. The plug is firing but it will not even crank or sputter. What am I missing???
Please help!
Thank you,
Mike
Old 09-19-09, 08:43 PM
cheese's Avatar
Does it have good compression? Have you cleaned the carb?
Old 09-20-09, 09:16 AM
I am not sure if it has good compression. I dont know how to check that. I did dismantle the Zama Carb and sprayed it down with carb cleaner. After reassembling I tried it again. I tried it on half choke and it sputtered. I then tried it again on no choke and it turned over and ran for 3 to 5 seconds and then died. I re-primed it and it did it again. I am stumped.
Thanks
Mike
Old 09-20-09, 05:56 PM
cheese's Avatar
Does the primer work well and circulate fuel through it?
Old 09-22-09, 08:56 PM
hopkinsr2's Avatar
Have you put a carb kit in it & adjusted the meatering leaver to spec??? The Zama website has some awesome service manuals,,, Check them out... Roger
