PowerPac Plus 2000 psi, Lifan 152f engine
shinrich's Avatar
MD
09-22-09, 09:51 AM   #1
I bought a used PowerPac Plus power washer, 2000 psi, it has a Lifan 152f engine. The machine looks almost new (the old owner said it was used only a few times), but I can't get it to start. I can pull and pull and get nothing - not even a sputter. I called the 800# on the machine and they said to disconnect the oil level cut-off, which I did, but still nothing. There is gas in the carb - but no prime system -
Does anyone have any experience with these motors? I've hooked water to the inlet but don't have an outlet hose - does that matter?
Airman's Avatar
TN
09-25-09, 09:20 AM   #2
From your description of the problem I would say a thorough cleaning of the carburetor is needed. This is a Chinese made engine with no service manual or technical support but I understand parts are available.
