Weedeater Head won't Turn?? Engine Runs
Old 09-28-09, 12:05 PM
I have a Troy Built weedeater (straight bar) that is no more than 1 year old. I was going to use it the other day when I noticed the problem.
The engine will crank and run as it should, but when you throttle up, the weedeater head will not turn. It just stays still, as if the engine was not even on.
Does anyone have any advise on how to correct this issue?? Thanks in advance!
Old 09-28-09, 05:45 PM
hopkinsr2's Avatar
Does Troy-bilt not have a 2 year warranty??? Check into it & let then fix it under warranty.... Roger
