Odd Lawnmower Engine Behavior
Old 10-02-09, 11:42 AM
I have a snapper lawnmower that sat in my shed for about 5 years without ever being used. I checked the oil (was very clean and level was good) and put gas in it and started it up. I ran it in the yard for about 15 minutes until it started slowing down and it slowed some more and more until it stopped. I made sure the spark plug wire was securely on the plug and even crimped the end of the cap a little for a snug fit. I checked the oil 10 times, and the level is great and it is very clear; it is just 5 years old or more.
Symptoms:
1.) I wouldn't say it sputtered ...the engine just got slower and slower till it stopped.
2.) White smoke was coming out while it got slower and slower;
3.) After trying to start it for 30-40 minutes, I let it sit for about 4 days, and on the first pull (without priming it) it started. But it ran very slowly for only about 10 seconds, then stopped.
4.) Every 3-4 days I try it and it runs slowly on the first pull for about 5-6 seconds. Funny thing is, I do not prime it. I DO prime it 3-4 days earlier when it stops ...in my attempt to start it again.
Question: What would be the first 1-3 things I should check into knowing these symptoms?
Thanks a million! -Tony17112
Old 10-02-09, 12:34 PM
What kind of engine is it? Approximately how old is the mower?
White-ish blue-ish smoke on a small 4 stroke is generally an indication that the engine is burning oil. If this is a briggs quantum engine, if you flipped the mower on the exhaust side side, you might have sent oil onto the air filter. Might want to check that. Try running it w/o the air filter temporarily to see if that improves things. Check the plug too - it might be fouled.
I'll reserve further comments for when we know what kind of engine it is.
- Joe
Old 10-02-09, 02:26 PM
Thanks!
I got the numbers off the mower and it's a:
Briggs & Stratton Intek 6.0 HP OHV.
126602 0110 E1 620117 FA, then on the silver exhaust is: 693331.
Would that fact that it ran for 15-20 minutes rule out the carb?
-Tony17112
Old 10-02-09, 11:02 PM
cheese's Avatar
I'd say change the plug, check the air filter and clean it, and if it still does this, you'll need to go into the carb.
Old 10-03-09, 11:24 AM
Boy do I feel stupid:
I did pull the air filter and she started right up. I did find that there's oil all over the filter. I mean ALL over it. I will search the forums here, but is it suposed to have a little oil in it? I doubt it.
-Tony17112
P.S. Thanks for answering my original simple question.
UPDATE:
I just checked the oil and it is indeed overfilled. Sitting in the shed for years and years, I must have overfilled it long ago and forgotten about it.
UPDATE #2: I just dropped the oil out and it was very, very liquidy. It almost acted like water would ...not a gel-like movement like fresh oil. I wonder if gas could have gotten in there? I doubt it. I dipped a paper towel in it and lit it up to see if it acted like gas and it was very hard to tell. I guess I could let it sit out in the bowl and see if the level goes down over a few days meaning that the gas would be evaporating ...where oil does not. Any comments are welcome. -Tony
You can assume all is well once I replce the air filter and oil ...unless you see another post by me.
Thanks again folks!! I love this place!
Old 10-03-09, 12:52 PM
indypower1's Avatar
You very well could have had water in the oil. 5 years in the shed could cause condesation due to temp changes and humidity changes.
If the air filter is foam, it should have some oil in it. Paper, NO.
