Snapper Hi Vac & Tecumseh TVM220
Bupkiss2003's Avatar
10-07-09, 12:53 PM   #1
Greetings -
I have currently replaced the old 5 hp motor on the snapper hi vac rear enging riding mower. My question is hot properly set up the throttle cable as i have it connected to the top of the thottle so i can at least use it. It is a 10hp. I have looked at it and scratched my head for a few days trying to figure this out.
I am not very mechanical...so....how do i set this up, and if you could make it idiot proof on explanantion i might be able to get it correct.
Thank you in advance
cheese's Avatar
GA
10-07-09, 07:07 PM   #2
There should be a regular clamp for the throttle cable on throttle control housing on the side of the engine to the right of the carburetor. Just hook the cable end in the bracket and put the cable in the clamp. Set the throttle to choke, then slide the cable through the clamp until it applies the choke, then tighten the clamp snug.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
10-08-09, 05:46 AM   #3
Great!!! Thank YOU! Will have to take a look and see.
