craftsman power washer won't start
dhansen46's Avatar
10-08-09, 07:44 AM   #1
I have a Craftsman power washer 580-751651 that won't start. I purchased the power washer at a garage sale. I replaced the carborator and still will not start. Where should I go from here. The carborator I purchase was a replacement from Sears.
thanks,
Dwight
BFHFixit's Avatar
KS
10-08-09, 08:37 AM   #2
Do you have spark? .
dhansen46's Avatar
10-08-09, 12:03 PM   #3
craftman power washer won't start
Yes, I had the air filter off and it would backfire in the carborator. It has gas. Could it be the intake value not opening. Is there a way to check it.
Dwight
BFHFixit's Avatar
KS
10-08-09, 12:22 PM   #4
Sears site has gone SOUTH so I can not determine what engine you have. That will be helpful. Post the engine numbers.
It does appear as though you may have a low oil sensor...?
Check for spark. Backfire does not confirm you have consistent spark.
Others with better resources for info than I will be more able to help.
dhansen46's Avatar
10-08-09, 01:21 PM   #5
It does have an oil sensor. I have made sure that it does have oil and the light is not coming on. I have pulled the plug and crank the engine and it does have spark. Let me know how to proceed.
thanks,
Dwight
hopkinsr2's Avatar
Non-US
10-08-09, 06:01 PM   #6
Since you have no idea of the past life this unit may have lived,, I think checking for compression may be a good place to start... You have spark & a new carb,, only one thing missing,,,, let's check if it has compression & go from there.... Roger
