Stator hook up
Old 10-08-09, 12:52 PM
Unhappy Stator hook up
Hi
I have taken the electric start system from a lawnmower and put it on a generator..everything works great except I need to know how to connect the 2 wire harness from the stator to the battery
so the engine will start from a toggle or push button switch and charge the battery.
Old 10-08-09, 04:48 PM
The configuration is different depending upon the stator. On the 3a DC, 5a AC stator, the red wire has the wire in it and should connect to the battery for charging. The yellow wire is used for lights, etc. and is AC. You probably won't have a use for it.
Do you need to know how to wire the starter to use a toggle or pushbutton?
