troy-bilt 5550
guitarslinger's Avatar
10-11-09, 06:01 AM   #1
troy-bilt 5550
I already had to clean my carb on my 5550 gen. It starts with one pull now, but it has a sputter I can't seem to get rid of. I have re-cleaned the carb and replaced the gaskets and sparkplug with the sputter remaining. HELP!
Engine Model 204412 Type 0147E1 Code 050329YE
Airman's Avatar
TN
10-11-09, 06:59 AM   #2
You were here before with carburetor problems and I see they are not resolved. I would like to help you. Once again I ask, please post the model, type and code of the engine.
Airman's Avatar
TN
10-11-09, 09:41 AM   #3
Verify the carburetor on your engine is a Nikki? I feel you still have a carburetor issue. Problems as you describe are normally caused by debris in the main jet/nozzle or air bleeds. Did you remove the jet and clean it thoroughly? Spray every hole, nook and cranny with aerosol carburetor cleaner and blow out with compressed air. I realize you have cleaned the carburetor but often it takes multiple cleanings to correct the condition.
Carburetor overhaul:
What are the procedures to follow when overhauling the carburetor?
Parts list:
http://www.briggsandstratton.com/mai...S6444_B_LO.pdf
Carburetion Troubleshooting:
http://www4.briggsandstratton.com/mi...ence_Guide.pdf
