how to test a excell devilbiss pump in a pressure washer
Old 10-15-09, 06:40 PM
hello, hello everyone, i am a newbie here.
I will like to ask how to test a pump from a pressure washer? the pump is a devilbiis.
thanks
Pedrodiesel
Old 10-16-09, 04:23 AM
Pressure testing is accomplished by installing a glycerin-filled pressure gauge between the pump outlet and the high-pressure hose.
Prior to testing pump pressure output, you must verify water flow input. This is correctly accomplished using a flow meter (rotameter).
If you have a problem we can assist with, post the model, serial number, etc. of the unit and pump. Not all DeVibliss pressure washers use DeVibliss pumps.
