New fuel line 1998 Toro 824 Snow blower
Old 10-28-09, 06:19 PM
sod
sod is offline
I just completed a complete rebuild on this snow blower' carburetor and figured I might as well replace the fuel line from the gas tank while I have it apart. I just went to pull the old fuel line and it feels stuck or at least a very tight fit. I decided to leave well enough alone until I had a chance to post here to see if there is a recommended method to use for replacing the fuel line. As it stands now I don't want to pull the old line and end up with two pieces at an inaccessible location. So I would appreciate any advice from those who are familiar with process.
The engine is the Tecumseh 8hp model HMSK80 155386 V.
Thanks.
Old 10-29-09, 05:27 PM
indypower1's Avatar
They can be a tight fit going thru the blower case. I just cut the line near the blower housing and pull it thru. I replace with the thin wall hose. (available at most small engine shops). Now to install the new hose, I use my 12" long phillips screw driver. I push the screwdriver shaft thru the hose, then slowly ease the hose thru the blower housing. Works everytime!!
Old 10-29-09, 06:16 PM
sod
sod is offline
Thanks indypower1, I will give it a try.
