How to adjust carb on husqvarna chainsaw model 141
Received 0 Votes
PLEASE INSTRUCT ON HOW TO ADJUST THE CARB ON MY CHAIN SAW ,i REPAIRED IT AND THE ADJUSTMENT IS OFF. PLEASE TELL THE ORDER AND ADJUSTMENTS .THANK YOU
Received 0 Votes
Carb adjustment
Saw was not running due to broken part of carb adaptor - pulse seal was broke .,carb was cleaned and now needs adjustment .,settings were lost .saw starts fine now but needs adj
Received 0 Votes
Parts list for Husqvarna (Poulan) 141 shows a Walbro WT carburetor. These links should help.
http://wem.walbro.com/distributors/s...s/WTseries.pdf
http://wem.walbro.com/distributors/s...viceManual.pdf
Received 0 Votes
put the screws (Both High and Low) all the way in. Then back them off about 1 turn each. After doing so start the saw make adjustments based on the sound of the saw. Adjust the idle as needed.
