Tec OVRM120 Series 8 Carburetor
I am going to replace the throttle shaft and rebuilt this carb. I have the Tec rebuild kit. The manual says to use new screws in the throttle plate. I 'd like to know before hand if the carb kit contains the new throttle plate screws. I see 4 screws in the kit. Or can I use Loctite 242 on the old throttle plate screws?
The throttle shutter only has one screw retaining it. I can’t imagine what the four screws in the kit are for. The throttle shutter screw has a history of coming out and thrashing engines. Installing the old with Loctite should be fine.
Normally carburetor kits are used for more than one model carburetor and this would explain the extra parts. In this case the 632760B kit is only used on about a dozen different OVRM120 carburetors.
