Echo SRM-211 Question
Old 11-08-09, 01:45 PM
My friend recently purchased an Echo SRM-211 from a garage sale. Everything runs fine on it. The only problem seems that the drive shaft was run over by a lawn tractor or something similar. This bent the shaft (its a straight shaft trimmer) and when he got it home, he literally put it in between two trees and bent it back. The thing runs fine with no problems, he went and used it with no flaw what so ever. However, should he be concerned that it was bent and then fixed? Could there be problems in the future? Thanks
Old 11-08-09, 09:38 PM
cheese's Avatar
if it has a flex cable, then probably no problems to worry about. If it has a solid drive shaft, then it could be a little out of line and maybe cause some vibration or something to wear the bushings in the tube, but if it runs well and without significant vibration, then I would use it and not worry about it.
Old 11-09-09, 07:28 AM
I tried it, there's no more vibration than on a normal unit. It's probably a flex cable, if it is...don't flex cables wear out faster than a solid shaft? Thanks
Old 11-09-09, 03:40 PM
cheese's Avatar
Not necessarily, at least in my experience. Solid shafts seem to tend to wear at the drive ends. Flex cables usually break before they wear out. Solid shafts are often in straight shaft trimmers and are better when using other attachments like tillers, blades, etc...
