Simplicity 755 Issues
Old 11-16-09, 06:47 AM
Hello all,
Just bought a used Simplicity 755 7HP snowthrower, model 1691413.
Previous owner installed a 7HP Briggs & Stratton model 121402-0194-E1 enigine. The original was a Tecumseh 7HP HSK70 from what I have found searching the internet.
The issue I have with this is that when I put the snowthrower in Reverse, it goes Forward. Also, the Forward gears put it in Reverse. Not a major issue, but one I would like to fix somehow.
I went to the Simplicity site and downloaded the manual it shows the belts come of 2 shafts; I have one shaft on the Briggs and Stratton. So, both my auger and drive are powered by 1 shaft with 2 pulleys. Thus causing the drive to go in opposite directions.
I looked for some Tecumseh engines but did not see any with dual shafts. Is this a common configuration?
Also, I was thinking I could maybe twist the belt like and "8" and that would allow the direction to be correct.
Not a major issue, the thing will go forward and reverse. I just have zero speed control in forward.
Thanks!
Old 11-17-09, 07:05 AM
No ideas to my engine and drive issues.
Old 11-17-09, 04:27 PM
hopkinsr2's Avatar
Yes, some Techumseh engines drove the wheels from the 2nd shaft that was the camshaft, thus it would turn the opposite direction & @ 1/2 the speed of the crankshaft... It sound like that is the problem,, Sorry,,, Roger
Old 11-17-09, 06:06 PM
I did a lot of research and found some that had 2 drives...rats.
Oh well, at least is still moves forward.
