Kohler CV730 oil leak
Old 11-21-09, 08:07 PM
A
Question Kohler CV730 oil leak
I have a Kohler CV730 in a Craftsman yard tractor. It started leaking oil under the #1 cylinder. It looks like it may be coming from the governor shaft or maybe the breather plate. It's dripping pretty good... Roughly 3 drops every 2 seconds.
I discovered the leak while I was mowing one day, after enough oil had dripped onto the muffler and it caught on fire. Fortunately I was just outside the shop door and was able to grab an extinguisher and put it out in a matter of seconds.
Does anyone know if there's a O-ring or some other seal on the governor shaft? I've checked the service manual but it doesn't mention any sort of seal.
What else would be a logical place on the lower right front of this engine where a leak could occur?
If it leaking from the governor shaft and there's no seal, what would cause it to leak here?
Thanks!
:USAF:
Old 11-21-09, 09:40 PM
A
After some more digging I've found that there's oil on the cooling fins near where the head and cylinder come together.
Blown head gasket?
Thanks
:USAF:
Old 11-22-09, 08:47 PM
A
Smile
Yup. It was a head gasket. #1 was blown and #2 was well on it's way.
It sounds like I might be replacing a lifter on #2 next. It runs fine though. Any thoughts on a noisy lifter? Will it pump back up on its own?
Thanks!
:USAF:
Old 11-23-09, 01:39 AM
cheese's Avatar
Received 89 Votes on 83 Posts
It should. If it doesn't in several minutes of run time, use 10w-30 oil instead of 30, if you aren't already and see if it improves.
