Snowblower belt change
Old 12-08-09, 06:28 AM
daswede's Avatar
I think i read on this forum that someone knew a way to change Snowblower belts without splitting the machine.
Anybody have a way to do this on a Ariens ST724 Sno-thro,model 932046, ser#015173? Two Stage.
Sure would be nice to not have to go through the hassle of splitting the machine in a snow storm.
Thanks
Old 12-08-09, 08:30 AM
indypower1's Avatar
You can try without splitting it. The big reasons you have to split it is to get clearance between the pullies to get the belts out & in and so you can make sure that you get the belt on the lower pulley and to have room to move the brake to properly instll the belt. I know it is a hassle, but also the easiest way to do it.
Old 12-08-09, 09:18 AM
BFHFixit's Avatar
Oh come on now indy, there is an easier solution and likely what the "train driver" who designed it actually had in mind any way....
Buy a New Snowblower
Old 12-08-09, 09:56 AM
daswede's Avatar
What piqued my interest in not splitting the machine along, with the hassle,was the unhappy experience the first time i had to split the machine to check some maintenance items.
The manual said that after splitting the machine to lower the handle bar to the ground. .... Wrong!!
That was a disaster as the bucket flipped off the tractor completely as the two bottom bolt holes are slotted, and bolts just popped off.
Thanks for the replies
