generator electric start conversion
Rick Stanley's Avatar
ME
12-12-09, 07:41 AM   #1
Hi, Newbe here,
I have 1998 Generac portable generator Model- 09778-4, Series-5500xl, serial-4551780, volts 12/240, amps-45.8/22.9, watts-5500
It is powered by a gasoline briggs and stratton 11hp, gn-320, part number-a1697, engine id no.- 93657......................10
It has a manual recoil pullcord start. It's hard to pull over in cold weather. The tin shroud/cover over the flywheel has a knock-out for a starter motor and the engine block has threaded holes for it. I want to change it over to electric start. I checked into this a couple years ago and found kits/with ring geared flywheel available in several places online. Should have done it then.
Anyway, I can't find the kits now. Any thoughts, tips, experiences, that you want to share would be very helpful.
Thank You!!
Rick
cheese's Avatar
GA
12-12-09, 11:19 AM   #2
You'll need the flywheel, starter, and charging stator. You should be able to find them easily. You need the engine model, type, and code. Probably a model 25XXXX if a flathead engine or 23XXXX if OHV.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
aj-allen's Avatar
CO
12-12-09, 01:27 PM   #3
It's not a Briggs
This is a Generac Power Systems Engine not Briggs. You would need a new flywheel part number 091222BSRV about $120.00 and a starter part number 0D92300ESV about $125.00 and a battery. You can use the 12 volt charging output of the generator to charge the battery
AJ
ME
12-12-09, 05:17 PM   #4
parts ordered
AH-HA!! You are right AJ. No wonder I couldn't find what I wanted.
I ordered the parts 5 minutes ago. Thanks a Million!!
