Tecumseh starter 37000
slimvinnie's Avatar
12-14-09, 08:13 AM   #1
I replaced the gear on my starter and once reassembled when I try starting it just hums. The shaft does not turn. I tried it on my bench, not installed on Snowblower. I can easily turn the shaft manually. I need help, thanks for any feedback
cheese's Avatar
GA
12-14-09, 10:05 AM   #2
Did the starter work prior to replacing the drive gear? Did you have the brush cap off?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
slimvinnie's Avatar
12-14-09, 10:45 AM   #3
The starter worked before. I did open the brush cap, as you know the brushes and springs come out of their sleeves when you open it. I was careful to replace the brushes where I believe they go, based on the length of the wires and placement of their connection to the motor.
cheese's Avatar
GA
12-14-09, 06:12 PM   #4
Sounds like something came apart or is shorted/connected wrong in the brush assembly. The 2 brushes connected to the cable post should be on opposite sides from each other, not next to each other. The wires from them should not be able to touch the wires from the other brushes or the armature or case of the starter. When you turn the starter, are you sure you're turning the entire starter motor, or maybe just the drive gear?
God bless!
slimvinnie's Avatar
12-14-09, 06:19 PM   #5
I will take it apart and try again. I am turning the shaft and not just the gear,will update, You think that its a short somewhere?
slimvinnie's Avatar
12-27-09, 09:22 AM   #6
Any other ideas out there???
sidny's Avatar
NY
12-27-09, 09:40 AM   #7
starter
Areyou sure it's not binding? Were thier any shims or washers at the mounting points. Try running it off the engine.
Sd
slimvinnie's Avatar
12-27-09, 11:31 AM   #8
I'm testing it on my bench, There was only one washer in the motor housing located on the top of the motor. It has a very small convex shape to it, I have tried it both ways with no success. I can turn the shaft with y fingertips, no effort, no binding
cheese's Avatar
GA
12-28-09, 12:24 AM   #9
Still sounds to me like either a short or no connection at the brushes. Are the brushes contacting the commutator?
God bless!
