Leaf Blower, 60 PSI, Gas coming out air filter
Old 12-14-09, 09:11 PM
I was given a non running Pulan pro leaf blower. It has a wierd grinding or chaffing sound, at best 60 psi, and the air filter gets half soaked with gas. Does this mean I have a bad valve?
Old 12-14-09, 09:46 PM
hopkinsr2's Avatar
60 PSI on a compression test??? 2 or 4 stroke?? is the grinding sound from the blower or the engine??? If it's a 2 stroke I think I'd pull the muffler off & have a look @ the piston & cylinder... Maybe post a Model & serial #,, but if that IS a compression reading you posted,, it sounds like problems,, (piston,, Cylinder, Etc) Sorry,,,, Roger
Old 12-14-09, 10:18 PM
What are good compression readings? Above 90 right?
Old 12-15-09, 12:00 AM
cheese's Avatar
Right. Pull the muffler and look, but I bet it's toast.
Old 12-15-09, 07:50 AM
Actually, it looks like itd be much easier to pull the jug off. No problems in doing that, right?
Old 12-15-09, 08:06 AM
What is the brand, model number, etc. of the blower.
If it is a low end unit, ryobi, homelite, poulan I would not waste my money.
Old 12-15-09, 08:35 PM
I took off the top, and the cylinder and piston ring were in great shape. Anywhere else I can be losing compression? I can barley get over 60PSI. This leaf blower looks brand new. I doubt its the head gasket. The grinding did sound like the blower. Thanks for the reccomendation.
