Yardmachines (MTD) 5 HP 22" snow thrower does not self propel
diy50's Avatar
NJ
12-21-09, 01:29 PM   #1
Hi I have Yardmachines (MTD) 5 HP 22" snow thrower.
model# : 31AS611D129 .
I just got it from a friend so I don't know too much about this snow thrower.
But this is very heavy , and I think it should self propled. documentation is very poor, so any one can help me with this it will be great.
Thanks!
Tolyn Ironhand's Avatar
MN
12-21-09, 03:37 PM   #2
Make sure the drive handle is in gear. Also make sure the pin is in the hub connecting the wheel to the axle on both sides.
indypower1's Avatar
NH
12-21-09, 04:34 PM   #3
Your snowblower is in deed self propelled. Check the belts. Make sure the cable from the lever is not broken. Let us know what you find.
Go here to find the parts breakdown:
Lawn Mower Parts - Quality Outdoor Power Equipment Parts for MTD Mowers, Lawn Equipment & More
diy50's Avatar
NJ
12-25-09, 07:42 PM   #4
Posted By: Tolyn Ironhand Make sure the drive handle is in gear. Also make sure the pin is in the hub connecting the wheel to the axle on both sides.
@Tolyn :
how do I do this? "make sure the pin is in the hub connecting the wheel to the axle on both sides"
@ IndyPower1: None of the cables are broken, This unit is like new!
Stick1's Avatar
12-26-09, 05:33 AM   #5
Yard Machine
How old is the machine? And are you able to roll in neutral? I have just repaired two of these with same problem. If you are mechanically inclined you can fix this your self. All you would need are a couple tools and some grease.I can walk you through it. Send private message if you need this help.:coffee
Attributes
Base Model -- [31AS611D129 (2004)]
Brand Name -- [Yard Machines]
Color of Unit -- [Black Jack 0691]
Engine -- [Tec 5.0hp HSSK50-67403]
Label Auger -- [777DO7482]
Auger Size -- [22 inches]
Manual -- [769-00861]
Wheel Assy -- [634-0114A]
Retailer-Brand -- [Home Depot - 029, 129, 229, 134, 138, 729, 929]
indypower1's Avatar
NH
12-26-09, 06:35 AM   #6
Your snowblower is 2004 model. I had 1 in here last month that was hard to push. The gear was stripped. That gear/shaft is $50. Took about an hour to replace. I also replaced the axle & gear shaft bushings.
diy50's Avatar
NJ
12-26-09, 08:52 AM   #7
your specs. are correct. But based on looks of the snow blower it is like new. As my friend gave it to me , I am not sure about how much it is used.
I am willing to do this if I can. So sure please walk me through this if you can.
there are total 7 gears 1 through 5 (forward) and 1 & 2 reverse,
I didn't see any neutral. but when I push, it goes forward I didn't see any change in speed by changing gears, even when the gear was 1st/2nd on reverse , I could push it forward with same force...
Thanks for all your help and assistance!
Regards
MN
12-26-09, 10:16 AM   #8
Posted By: diy50 @Tolyn :
On each side of the axle there is (or should be) a hole with a lynch pin going through both the axle and wheel. If it just goes through the axle, or is missing, the axle will not turn the wheel(s).
Stick1's Avatar
12-26-09, 12:50 PM   #9
Posted By: diy50 your specs. are correct. But based on looks of the snow blower it is like new. As my friend gave it to me , I am not sure about how much it is used.
Regards
Put the gear in 3 without motor running. Pull both levers and let me know if you can still move machine. If you can it might be like Indy said , Belt or a case where the cable is not pulling the friction disk in tight to the drive plate. The engine spins the the friction wheel. when you pull on lever it pulls the rubber disk(friction disk) to make contact with friction wheel. Does the machine move at all when running and also when running lift by handles to lift wheels off ground about an inch with clutch engaged and let us know if wheels turn at all.
indypower1's Avatar
NH
12-26-09, 04:44 PM   #10
Regards
There is no neutral on any snowblowers. Neutral is when you release the lever on the handlebar. That disengages the friction wheel from the drive disc. You should be able to easily push it when not holding down the lever. Holding down the lever engages the friction wheel to the drive disc.
38racing's Avatar
CANADA
12-27-09, 06:14 PM   #11
Posted By: indypower1 There is no neutral on any snowblowers. Neutral is when you release the lever on the handlebar. That disengages the friction wheel from the drive disc. You should be able to easily push it when not holding down the lever. Holding down the lever engages the friction wheel to the drive disc.
MTD's 600 series had a neutral position prior to 1992.
diy50's Avatar
NJ
12-28-09, 04:31 PM   #12
Thanks for all your suggestions..
I updated this video to show that it moves in any gear with/without pulling the leaver.
video
also pics..
pics
so what do I need to fix this!
indypower1's Avatar
NH
12-28-09, 08:46 PM   #13
You are going to have to securly prop it up on the auger bucket so you can remove the bottom pan. You will most likely need to replace the rubber friction drive disc. You should not be able to move it with the lever pressed. To see a breakdown, go here:
MTD Corporate :: Homepage
diy50's Avatar
NJ
12-30-09, 07:10 AM   #14
@indypower1,
I did not understand your suggestion. I understood, I will need to replace the rubber friction drive disc.
but how should I do it? any video / pics guidence ?
I went to the link that you provided but it goes to general MTD homepage no specific direction on how to do this!
Thanks for your help.
indypower1's Avatar
NH
12-30-09, 12:35 PM   #15
Here is a break down of the drive system. You need to remove the bottom pan to gain access.
jwroblesk's Avatar
12-30-09, 12:47 PM   #16
Replacement Gear for MTD 717-1290 & 717-1413,1444
I had a similar problem and found it was the gear shaft-the splines had worn down. If you have an MTD the shaft is no longer available but MTD part # 917-04094 will replace the above shafts. (717-1290, 717-1413 717-1444) It's actually a Yard Machine brand made by MTD. The shaft is virtually identical except it's 7 spline rather than 8 so your machine will go slightly faster. Otherwise it's a perfect fit and less than an hour job to replace it.
diy50's Avatar
NJ
12-30-09, 05:45 PM   #17
guys, thank you very much for your help and suggestion. based on what indypower1 has suggested , I might need to replace the friction disk and diagram he provided .
Apperently it is not trivial and looks complex. If I loose one of those screws or assembly I will have bigger issue, So I have decided to go to take this unit to a service station..
Thanks again for all your help.
Regards!
