Troy-Bilt WON'T START-NEW
Old 12-28-09, 07:53 PM
B
Exclamation Troy-Bilt WON'T START-NEW
I realize this was extremely stupid to do, but I purchased a Troy-Bilt Storm 9.5 28" Self-Propelled Snow Thrower in 2007, and never started it before this last big snow in Virginia.
I've tried everything. I'm a female but have worked on everything from lawnmowers to replacing motors in commercial carpet cleaners, and everything in between. I was brought up as a tomboy and know more about engines and male dominated hobbies than some men I know!
I have determined that there is no spark coming from the cord that fits over the spark plug. I did the handy screwdriver to contact to metal test. To me this isn't a good sign, but I thought perhaps someone who has snow thrower knowledge could help me troubleshoot.
I'm thinking it may be the coil but cannot find a schematic that shows where the heck the coil is located. I also wanted to price one but cannot find a link to that part on the MTD site. I suppose they want you to send it out for service instead of replacing it yourself!
My question is: The electric start works, but the engine will not run. MTD said it sounds like something is grounding it out. This stupid thing is brand new. Anyone have any suggestions as to how I can find out if it is the coil? Suggestions welcome and appreciated.
Also, yes I have the key in, gas, oil, correct choke and throttle position, and proper gauge extension cord.
Thank you, Bondogirl
Old 12-28-09, 08:08 PM
A
Received 4 Upvotes on 4 Posts
It is most likely not the coil. I know that you said that you have the key in but it must be pushed in untill it snaps in. Check that and than put a tea spoon of gas into the spark plug hole put the plug back in and try to start it.
AJ
Old 12-29-09, 08:38 AM
bontai Joe's Avatar
If there is no spark, then unless there is mouse damage to the wiring, you have a loose wire or the key is not properly inserted or turned to the correct position.
Old 12-29-09, 09:44 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
I don't have much use for a snowblower , but any chance it's a safety switch of some kind like on a riding mower?
Old 12-29-09, 10:37 AM
indypower1's Avatar
No saftey switches on snowblowers. They are closer to a push mower set up.
Old 12-29-09, 04:05 PM
B
Thank you for the responses. The key is snapped in correctly. I called MTD today and although I am 1 month past my 2 year limited warranty they said they will fix something that was a factory problem.
I'm still thinking it's the coil since I have no spark from the plug wire, but I don't want to dismantle the thing to test the coil if they may cover it under warranty.
I'm taking it in tomorrow and when I get the verdit, I will post the result.
Thank you everyone for your responses.
Bongogirl
