Craftsman Snowblower w/tracks wont self propel
Received 0 Votes
Hi everyone im new here just looking for some advice ...i have a sears craftsman 2 steerable trac snowblower 8/26
model # c459-52128
when i pull the lever to move forward in any gear it just sits there sometimes i can move it by hitting the steering levers side to side...sometimes it works but slowly and wont go through heavy snow...i have to push it alot
machine runs good and throws snow well.
i cant find a manual or any info on it its about 7 years old maybe more..thanks for any info or tips
model # c459-52128
I tried to find info on your snowblower. Sears Canada does not have the info that Sears U.S. has. I did make a phone call and found out your snowblower was made by "Technics". I did a search for that name and found nothing relating to snowblowers.
Received 0 Votes
thanks any idea what could cause these symptoms? i think its a chain drive not a belt...
i searched my number and got a mtd cross reference not sure if thats what make it is though
Received 0 Votes
Steerable Trac.
Hi Dave.
I know this is an old thread but I was wondering if you solved your problem. I have the same machine and I think that you may need a new drive disk. It is a very simple job to do except if it is cold when you work on the machine. The cold always adds to difficulty level. Also If you want the manual I can scan it and email it to you.
If you still have this machine and it is still not working, I could sure a few of the parts from it as mine is now down.
Thanks.
Rob.
Thanks.
Rob.
